I created parts and saved as dwg file from Inventor Fusion 2012 for AutoCAD Mep 2011. I can insert one part with no problem, however, when I insert a second part it takes on the first parts properties. (i.e. same size and shape). Yet in the properties box it shows it as being a different part. Any suggestions?
Edited by
Discussion_Admin
Can you post the parts here? I can forward them to QA for testing.
Loren Jahraus
Fusion SME/tech writer
I opened the parts one at a time in both AutoCAD and Fusion, and they basically have the same dimensions. I didn't check everything but the main body seems to be the same size while the cylindrical fetaure has a different diameter.
At this point, it isn't clear what the problem is. If you can tell us which dimensions are different in the two programs, then we can look into it. If the parts have changed size, then we would need the original files and the steps that caused them to change.
Loren Jahraus
Inventor Fusion Technical Writer, SME
The problem is that when ever I insert say a part with a 6" in diameter intake valve into a drawing it inserts fine. Then in the same drawing whenever I insert another part that has different diameter intake say an 8" or 14"... into the same drawing it shows as the part I want inserted (8" or 14") yet the part is the body and dimensions as the first part I insert (6" diameter intake). Yet when you click on the properties of the second part inserted it reads as a 8" or 14" diameter intake. So in recap I can insert one part just fine, yet when I insert any other part it is the body of the first part inserted, yet the properties read as something different.
I'm sorry I couldn't get back to you sooner. I am also seeing this problem, and it is certainly unusual. I have seen a lot of things over the years, but this is a new one for me.
How did you create the parts in Fusion? Did you create one part and then save copies with the different feature sizes?
There is definitely something wrong with these files. I imported them into Inventor and then exported them again as DWGs, and they seem to work now. It doesn't resolve the original problem, but at least the files should be usable now.
I forwarded this to QA.
Did you use Inventor Fusion to import the parts into? I do not have Inventor and do not see the options to import dwg's into Inventor Fusion.
I used Inventor initially, but this also worked for me.
I was able to insert the files correctly after translating them. It looks like Fusion is creating DWG files with an internal name that doesn't increment when you insert them into ACAD. Even though the blocks have the correct file properties, ACAD sees them as the same block and reuses the geometry. Saving them in a different format and then converting them to DWG fixes this issue.
Ok, I saved the Inventor Fusion file as an .sat file. When I try to import the file into AutoCAD 2012 I get an error that says, "Youhave selected an unsupported DGN file. Only V7 and V8 DGN files are supported.". Any suggestions?
DGN is a Microstation format, and Fusion doesn't export that file type.
Have you installed SP2 for Fusion?
http://usa.autodesk.com/adsk/servlet/ps/index?id=16916662&siteID=123112&linkID=16915701
I have SP2 installed on my computer, I have remade the parts and saved them as .sat files. I next open up a new autocad 2012 dwg and try to import the file I get the following error (see attachment). So I am open to suggestions on this matter.
thanks
Here are the three files that I imported to ACAD.
Can you post one of the SAT files you created?
Please correct the highlighted errors and try again.
It did not look like my last post went through, so here it is again. I get the error above whenever I try to post the .sat file.
I think you need to zip the file before you post it.
I am having the same issue...parts created in Fusion cannot be inserted into AutoCAD because they are all called ACAD_FREEWAY_COMPONENT_1. I cannot insert more than one part in Fusion, either. I'm sure there are workarounds, but the main takeaway is that Fusion and AutoCAD are only marginally compatible.
I have partially managed to get around this by exploding each inserted part and using the RENAME command to change the parts from ACAD_FREEWAY_COMPONENT_1 to a unique name.
I'm quite enthralled with the idea that I can use an Inventor interface to work with DWG files, but there are definitely some kinks to work out.
This is an issue in Fusion that the development team is investigating. In the meantime, the workaround is to save files in a neutral format, import them into another Autodesk product, and then save as DWG.
