Hi
Im having problems with the constraints between fusion and autoCAD. In fusion they are all working but when opened in autoCAD one of the main constraints dissapears and the component is moved. How can I fix this?
Thanks 🙂
Does this happen in only one case?
Can you attach some data or a before/after screen shot? This would help us to figure out what happened.
Phil Eichmiller
Quality Assurance Team
When opening Fusion dwg in AutoCAD, all the assembly constraints will be removed by AutoCAD. This is as expected.
While the position of components shouldn't be changed, so please share the dataset with us so we can take a look.
Macro Liu
Inventor Fusion QA
