Inventor Fusion
New Member
daguren
Message 1 of 2 (403 Views)
Whence (Mac) transparency (and others)?
403 Views, 1 Replies
01-25-2013 09:12 AM
Learning Mac Inventor Fusion 2013. I can't find yet commands (menu or command line) to modify the transparency/opacity of a body/surface/edge (besides the quite dull and unuseful "glass" material).
Are there plans to provide IF access to the more extensive AutoCAD materials library?
Similarly, I can't find a way to display/edit (manually) an object's position or dimensions relative to (a select) origin.
I'm enjoying the product! Many thanks.
Employee
SallyYang
Message 2 of 2 (378 Views)
Re: Whence (Mac) transparency (and others)?
02-06-2013 10:05 PM in reply to: daguren
Thanks for your feedbacks. It's very helpful to hear the voice from customer and make our functionality more reasonable.
About transparency and material requirement, we have adopted it in future releases.
And for position and dimension issue, we will consider as an improvement for them.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
