Learning Mac Inventor Fusion 2013. I can't find yet commands (menu or command line) to modify the transparency/opacity of a body/surface/edge (besides the quite dull and unuseful "glass" material).
Are there plans to provide IF access to the more extensive AutoCAD materials library?
Similarly, I can't find a way to display/edit (manually) an object's position or dimensions relative to (a select) origin.
I'm enjoying the product! Many thanks.
