• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Active Member
    What IS fusion?
    567 Views, 9 Replies
    08-23-2012 08:08 AM
    or maybe, "What's the difference between Inventor and Inventor Fusion?"
    When I started working in the office I found that it had Fusion already loaded on the computer, although no one in this office knows how to use it (?don't ask me). So I brought an Inventor text book hoping to learn Inventor during my lunch breaks.
    The first thing I notice is that most of the pull down menus named in the text book don't exist and the book doesn't tell me how to turn on the menus. I see some command pallets at the top but not nearly as many as named in the book.
    Without those menus I'm stuck wondering how to follow the intructions in the texbook. Every command it names is another that I can't find.
    Am I looking at a completely different program where the Inventor book won't help me at all? Or can someone tell me how to turn on the menus? I also notice that there is no place in Fusion to find tutorials.
    Please use plain text.
    Employee
    Re: What IS fusion?
    08-23-2012 12:12 PM in reply to: randyscott1
    Hi Randy (or is it Scott?),
    Yes, Inventor and Inventor Fusion are two different applications both from Autodesk. I am not aware of any books for Fusion. I would recommend starting with the WikiHelp specifically the Essentials Videos and the tutorials (tutorials are currently only for the Windows version of Fusion).
    If you have questions, you can comment in the wiki or post in these discussion groups. Best of luck!
    Fusion for PC (Windows)
    http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013
    Fusion for Mac
    http://wikihelp.autodesk.com/Inventor_Fusion_Technology_for_Mac/enu/TP1
    Patrick Miller
    Senior Content Developer
    Autodesk, Inc.
    Distinguished Contributor
    Ryan.Martinez
    Re: What IS fusion?
    08-24-2012 06:54 AM in reply to: randyscott1
    Fusion is NOT a history based modeler. It excels at modifying non-native cad data for use in inventor. It can even break down a .stp/.stl/.prt ect into features that can then be pulled back into inventor. I have taken a couple classes at AU and watched some online classes. I would suggest going to the AU website and finding the fusion classes at watching them. The speaker last year was really good at breaking fusion down so I could understand it.
    Product Design Suite 2013
    New Member
    Re: What IS fusion?
    09-16-2012 11:17 PM in reply to: randyscott1
    what is the difference between the package of autocad fusion and autocad software..
    why is the advantage of using fusion instead of autocad.
    can any type of drawing done by autocad......
    what is the disadvantage of fusion..
    Employee
    Re: What IS fusion?
    09-17-2012 01:17 AM in reply to: dipakfortyfive
    Hi
    Thanks your questions.
    #1 The difference of Fusion and AutoCAD.
    Fusion is a new product of Autodesk. The differece, I think, is Fusion can create 3D model easily. There is a Add-in Fusion in AutoCAD. It can easy to switch between AutoCAD and Fusion quickly.
    #2 The advantage of Fusion.
    It's easy to use, firstly. It based on directly model tech. It's 3D modeling product. But it will not instead of AutoCAD.
    #3 can any type of drawing done by autocad?
    I'm not sure. But I think most of drawing can be done in AutoCAD. We are tring to make our produce perfect.
    #4. The disadvantage of fusion
    Fusion is a new product. so there are some limitation of Fusion, comparing the mature 3D modeling product. If your think there are some disadvantage on Fusino, please feel free to tell us. We are very appreciated your suggestions.
    Cathy
    Autodesk, Inc
    (Please mark this response as "Accept as Solution" if it answers your question)
    Active Member
    Re: What IS fusion?
    09-18-2012 09:58 AM in reply to: Cathy.Wang_Autodesk
    The first disadvantage I would like to point out is that there are no menus and only a limited number of "ribbon" toolbars. None of the common commands I know from Autocad are available in Fusion.
    I have not yet had a chance to look for the tutorials named above so I can't say anything further yet.
    Employee
    Re: What IS fusion?
    09-18-2012 06:48 PM in reply to: randyscott1
    Hi Randy,
    Thanks you to point it out.
    Yeah, Fusion is different to AutoCAD.  It's a new CAD product using Directly Modeling Tech. It makes create model and edit model very easily.
    Enjoy it!
    Cathy
    Autodesk, Inc.
    Active Member
    Re: What IS fusion?
    09-21-2012 10:13 AM in reply to: randyscott1
    Thanks for trying Cathy, but I have to disagree. I'm finding it very confusing and frustrating.
    I am following the directions given in the wiki and they aren't working as presented.
    I have applied for an ID so I can watch the videos but Autodesk does not reply. I have used "Forgot my password" and get no response. I tried to register again and it said "this email is already registered".
    I have tried several times to sketch with the instructions in the wiki and the sketch always disappears.
    Why does Autodesk create such a complicated software if they don't intend to create a comprehensive instruction manual? Why does Autodesk claim they will help when they obviously refuse to help?
    *Expert Elite*
    Re: What IS fusion?
    09-22-2012 06:01 AM in reply to: randyscott1
    Anyone should be able to see the videos, sounds like you don't have the correct plug-in installed (sorry, I forget what the name is of the plug-in but I had to install it on my machine to see the videos).
    Also search for past Kevin Schnieder classes here http://au.autodesk.com
    I would not expect a comprehensive instruction manual for a free product - Autodesk has several commercial products for design.  But with the wiki Help and Tutorials you (and other users) can generate the comprehesive help.
    You might read this thread http://forums.autodesk.com/t5/Inventor-Fusion/3D-model-doesn-t-work-anymore/td-p/3623616 especially the first and last posts.
    Board Manager
    schneik
    Re: What IS fusion?
    09-22-2012 10:15 AM in reply to: randyscott1
    Can you be more specific in what you mean when you sat the sketch disappears?
    Also are you using MAC or Windows version.
    I am sure we can get you started if we figure out why the software is not behaving as expected.
    Kevin Schneider
