• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Sweep not working to create cylinder
    280 Views, 4 Replies
    12-28-2012 05:20 PM
    I created a circle and a path coming from the center (sorry for the lack of terminology). I wanted to use sweep to form a cylinder around the path with the circle being the diameter of the cylinder. However it won't light up the tick to accept it. I am not sure what I am doing wrong.
    Please use plain text.
    Re: Sweep not working to create cylinder
    12-31-2012 09:42 AM in reply to: neatgadgets
    The circle is on same plane as the path.
    It should be on a plane perpendicular to the path.
    Inventor Professional 2014 Edu 64-bit
    Member
    12-31-2012 03:30 PM in reply to: JDMather
    Thankyou for your reply. Happy New Years to you as well.
    I though I had it perpendicular to the path. How do I get it perpendicular to the path?
    Employee
    Mike.Zhang
    01-17-2013 10:43 PM in reply to: neatgadgets
    I notice you only have one Sketch in your file, you need add 2nd Sketch which vertical the 1st sketch.
    How to?
    1.Toggle on the lamp before the Origin
    2.Click the vertical workplane
    3.Select New Sketch
    4.Draw a line you want
    5.Invoke Sweep command
    6.First select your 1st profile
    7.Then click the new line
    8.OK.
    [Mike.Zhang]
    [SQA Engineer]
    [Fusion 360] Quality Assurance Team
    Member
    05-19-2013 02:18 PM in reply to: neatgadgets
    Thankyou for your reply, sorry for the delay, I have only just gotten back into Inventor.
