• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    Stuck on wired display
    278 Views, 11 Replies
    02-10-2013 02:02 AM
    The problem is that i keep on trying to change the display to shaded but it doesn't change, before when i used to make a cube it used to be a grey 3-d shape but now this is what I get. Even the visual and physical materials cant be changed
    Please use plain text.
    Employee
    Phil.E
    Re: Stuck on wired display
    02-15-2013 09:37 AM in reply to: srivat1
    Have you checked for new video drivers?
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Autodesk, Inc.
    Member
    02-17-2013 05:11 PM in reply to: srivat1
    I am having the same issue. My drivers are all up to date, since i am using a mac (driver updates come with system updates). Any idea how to fix this?
    Employee
    Phil.E
    02-19-2013 03:01 PM in reply to: xkoh
    On Mac, are you in power saver mode or using a VM?
    Phil Eichmiller
    Autodesk, Inc.
    Member
    02-19-2013 08:03 PM in reply to: srivat1
    no, I am not on power saver or using a VM. I am running everything normally. I even tried resetting the computer, updating all drivers, etc.
    Employee
    Phil.E
    02-20-2013 08:26 AM in reply to: xkoh
    Sorry, but a couple more questions:
    What is your graphics card?
    Mac model and OS:
    Phil Eichmiller
    Autodesk, Inc.
    Member
    02-20-2013 03:26 PM in reply to: Phil.E
    MacBookPro 6,2 (Mid 2010 Model) (High-res display)
    Core i7
    GPU: Nvidia GeForce GT 330M
    OS: Mac OS X 10.8.2
    Employee
    Phil.E
    02-27-2013 04:28 PM in reply to: srivat1
    Thanks for your information! I need a little more:
    What language/locale is your OS set on?
    Phil Eichmiller
    Autodesk, Inc.
    Member
    02-27-2013 07:35 PM in reply to: Phil.E
    It is set to English, and it's location is United States.
    Employee
    04-08-2013 10:48 PM in reply to: srivat1
    Thanks for bringing up the issue, Now we have logged defect UP-5832 to track the issue.
    BTW, I also met the issue one time, it is just because that i don't install the complete material library. So you can have a try to see whether can solve the issue. Thanks.
    Autodesk ACRD Neutron/Cloud Platform QA
