• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Snaps, the Inventor/Fusion way
    546 Views, 3 Replies
    06-26-2012 02:21 AM
    I am new to Fusion & have never used Inventor so excuse some basic questions (I have searched the wikihelp), I am struggling to move from Autocad mode to Inventor/Fusion mode with some basic commands/processes my biggest problem is the lack of snap points to relate basic setting out from.
    Move that basic of commands is also difficult when you cannot pick a base point on an object to grab or a snap point to move to. Sketch geometry is the way I think but I still cannot move a solid from a useful point (i.e. centre) to move it to a sketch point?
    I am also frustrated by the fact I can create work points/axis from solid data (see attached jpeg) but cannot use them points to snap onto! it is somewhat frustrating but obv I just need to learn the new skill set for this software.
    Please use plain text.
    Member
    Re: Snaps, the Inventor/Fusion way
    06-26-2012 03:25 AM in reply to: JWPepper
    managed to snap to the workpoint, not sure how but starting a new sketch plane seemed to work, still cannot use move/triad with any use though
    Employee
    Phil.E
    06-29-2012 04:45 PM in reply to: JWPepper
    To position components:
    Have you tried using the Assemble command? (Home tab> Constrain & Dimension panel)
    Phil Eichmiller
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Member
    07-02-2012 12:38 AM in reply to: JWPepper
    Yes, I have used it - previously I was trying to use assemble on items that were part of the original solid before I found that I had to create separate items as new components (I thought by default new items created would be separate & not part of the original solid)
