Inventor Fusion
Member
Message 1 of 4 (941 Views)
Snaps, the Inventor/Fusion way
941 Views, 3 Replies
06-26-2012 02:21 AM
I am new to Fusion & have never used Inventor so excuse some basic questions (I have searched the wikihelp), I am struggling to move from Autocad mode to Inventor/Fusion mode with some basic commands/processes my biggest problem is the lack of snap points to relate basic setting out from.
Move that basic of commands is also difficult when you cannot pick a base point on an object to grab or a snap point to move to. Sketch geometry is the way I think but I still cannot move a solid from a useful point (i.e. centre) to move it to a sketch point?
I am also frustrated by the fact I can create work points/axis from solid data (see attached jpeg) but cannot use them points to snap onto! it is somewhat frustrating but obv I just need to learn the new skill set for this software.
Member
Message 2 of 4 (938 Views)
Re: Snaps, the Inventor/Fusion way
06-26-2012 03:25 AM in reply to: JWPepper
managed to snap to the workpoint, not sure how but starting a new sketch plane seemed to work, still cannot use move/triad with any use though
Board Manager
Phil.E
Message 3 of 4 (914 Views)
06-29-2012 04:45 PM in reply to: JWPepper
To position components:
Have you tried using the Assemble command? (Home tab> Constrain & Dimension panel)
Phil Eichmiller
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Member
Message 4 of 4 (902 Views)
07-02-2012 12:38 AM in reply to: JWPepper
Yes, I have used it - previously I was trying to use assemble on items that were part of the original solid before I found that I had to create separate items as new components (I thought by default new items created would be separate & not part of the original solid)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
