Inventor Fusion
New Member
ttfisker
Message 1 of 3 (236 Views)
Save dwg as 'Wireframe with Visible Edges Only'
236 Views, 2 Replies
01-30-2014 02:23 AM
In Inventor Fusion under View -> Visual Styles, you can change the view to 'Wireframe with Visible Edges Only'.
How do I save the object in this view mode as dwg?
If I just save it as *.dwg it will be meshed once opened in Autocad LT and apart from Autocad there is no 'Visual styles' in Autocad LT.
See enclosed example
Board Manager
Phil.E
Message 2 of 3 (221 Views)
Re: Save dwg as 'Wireframe with Visible Edges Only'
01-31-2014 08:07 AM in reply to: ttfisker
The visual style is set by the program. The model is always the model, and the visual setting is how the software displays the model for you. If you only see mesh in AutoCAD LT it is due to limitations in AutoCAD LT, not because of the way Fusion is saving the model file.
Looking at the comparrison page between AutoCAD LT and regular AutoCAD it shows that LT does not support 3D.
http://www.autodesk.com/products/autodesk-autocad-lt/compare/compare-products
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Autodesk, Inc.
New Member
ttfisker
Message 3 of 3 (211 Views)
02-03-2014 12:42 AM in reply to: Phil.E
I know of the FLATSHOT command in Autocad and also the visual styles supported by the 3D 'module' in Autocad.
Also, like you say, the Inventor Fusion View is a certain rendering of the model object but I hoped there would be some sort of workaround.
How about other software then? Do you know if it's possible to do 'FLATSHOT'-like (mesh removing) functions in other (preferably free) software.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
