Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
STL files in Fusion?
1 REPLY 1
757 Views, 1 Reply
I wonder if anyone works with STL files?  If so, perhaps you know what Fusion can do with them.  I opened an STL file which placed a "Mesh" object in the tree but there doesn't seem to be any way of using it.  None of the commands seems to be set up to work with the mesh. The wiki help does not "help" unfortunately.
Any help appreciated.
Petr
1 REPLY 1
Phil.E
STL files are only used for visual reference within Fusion.
Also note that STL files have surface geometry that is converted for 3D printing into triangular regions, often referred to as facets. For this reason they are not considered worthwhile to use for any kind of CAD/CAM that involves accuracy.
Phil Eichmiller
Phil Eichmiller
Software Engineer
Quality Assurance
