• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Active Contributor
    sciguy77
    Accepted Solution
    Patterning error?
    226 Views, 5 Replies
    05-15-2012 04:43 PM
    I have a fairly simple design for a watch case I'm making. I'm trying to pattern a cylender around the body of the watch in a circular patter, but I get this error: "Failed to make tool sheet from feature faceset"
    What does this mean and how do I resolve it?
    Attached is a screen shot (too big to post, apparently).
    Please use plain text.
    Board Manager
    schneik
    Re: Patterning error?
    05-15-2012 06:28 PM in reply to: sciguy77
    Can you post the f3d file? I tried to replicate the error and could not.
    Kevin Schneider
    Active Contributor
    sciguy77
    05-15-2012 06:42 PM in reply to: schneik
    Sure thing. Thanks for the help. :smileyhappy:
    Board Manager
    schneik
    05-20-2012 04:18 PM in reply to: sciguy77
    There was a seam on the bottom face:
    I used press pull and snapped to the bottom face ( .03 mm distace) to make the faces merge:
    After that the pattern works fine.
    Here is the final model too as an attachment.
    Kevin Schneider
    Active Contributor
    sciguy77
    05-20-2012 04:59 PM in reply to: schneik
    Fantastic, thank you so much!
    Board Manager
    schneik
    05-20-2012 08:05 PM in reply to: sciguy77
    Be sure to post an image of your finished design to our facebook page!
    Kevin Schneider
