Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Patterning error?
5 REPLIES 5
850 Views, 5 Replies
Patterning error?
I have a fairly simple design for a watch case I'm making. I'm trying to pattern a cylender around the body of the watch in a circular patter, but I get this error: "Failed to make tool sheet from feature faceset"
What does this mean and how do I resolve it?
Attached is a screen shot (too big to post, apparently).
5 REPLIES 5
schneik-adsk
Can you post the f3d file? I tried to replicate the error and could not.
Kevin Schneider
in reply to: schneik-adsk
Sure thing. Thanks for the help. 🙂
schneik-adsk
There was a seam on the bottom face:
I used press pull and snapped to the bottom face ( .03 mm distace) to make the faces merge:
After that the pattern works fine.
Here is the final model too as an attachment.
Kevin Schneider
Fantastic, thank you so much!
schneik-adsk
Be sure to post an image of your finished design to our facebook page!
Kevin Schneider
