Inventor Fusion
Active Contributor
sciguy77
Message 1 of 6 (316 Views)
Patterning error?
316 Views, 5 Replies
05-15-2012 04:43 PM
I have a fairly simple design for a watch case I'm making. I'm trying to pattern a cylender around the body of the watch in a circular patter, but I get this error: "Failed to make tool sheet from feature faceset"
What does this mean and how do I resolve it?
Attached is a screen shot (too big to post, apparently).
Board Manager
schneik
Message 2 of 6 (312 Views)
Re: Patterning error?
05-15-2012 06:28 PM in reply to: sciguy77
Can you post the f3d file? I tried to replicate the error and could not.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Contributor
sciguy77
Message 3 of 6 (308 Views)
05-15-2012 06:42 PM in reply to: schneik
Sure thing. Thanks for the help. :smileyhappy:
Board Manager
schneik
Message 4 of 6 (275 Views)
05-20-2012 04:18 PM in reply to: sciguy77
There was a seam on the bottom face:
I used press pull and snapped to the bottom face ( .03 mm distace) to make the faces merge:
After that the pattern works fine.
Here is the final model too as an attachment.
Kevin Schneider
Active Contributor
sciguy77
Message 5 of 6 (273 Views)
05-20-2012 04:59 PM in reply to: schneik
Fantastic, thank you so much!
Board Manager
schneik
Message 6 of 6 (265 Views)
05-20-2012 08:05 PM in reply to: sciguy77
Be sure to post an image of your finished design to our facebook page!
Kevin Schneider
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
