Inventor Fusion
Member
MrNickBarker
Message 1 of 8 (762 Views)
Parallelogram mechanism
762 Views, 7 Replies
12-04-2012 10:53 AM
I'm trying to build a simple parallelogram mechanism which should lift a top plane.
My problem is that as soon as I add the last joint the model won't move and I get "Distance conflict due to joint type".
I'm guessing that it's mechally imposible for the joints to move the way they are setup, I've attached an image so you can see better.
Thanks in advance.
JDMather
Message 2 of 8 (757 Views)
Re: Parallelogram mechanism
12-04-2012 02:12 PM in reply to: MrNickBarker
Can you attach the dwg file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
MrNickBarker
Message 3 of 8 (753 Views)
12-04-2012 02:36 PM in reply to: JDMather
The file format which Inventor Fusion for Mac allows me to save is f3d and this forum doesn't allow f3d extensions for attachments, so I just replaced the extension with .dwg change to .f3d to open again.
I tried to use export but there isn't dwg there either.
JDMather
Message 4 of 8 (744 Views)
12-05-2012 08:29 AM in reply to: MrNickBarker
I didn't realize you were using Mac version or that Mac version would not allow you to save dwg.
Member
MrNickBarker
Message 5 of 8 (742 Views)
12-05-2012 08:33 AM in reply to: MrNickBarker
It allows me to export to SAT, STL or STEP. When saving there is no option to choose type, it just saves it as f3d.
Board Manager
Phil.E
Message 6 of 8 (735 Views)
12-05-2012 09:50 AM in reply to: MrNickBarker
Looking at your model I see a few problems. See attached image.
The joint origins are not lined up. This will cause the mechanism to bind. A mechanism like this requires the same joint origin spacing on both parts that the link bars are linking.
Please mark this response as "Accept as Solution" if it answers your question
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Member
MrNickBarker
Message 7 of 8 (731 Views)
12-05-2012 10:38 AM in reply to: Phil.E
Thanks, thats what I figured.
Is there an easy way to align joint origins or to snap them toghether? A link to a tutorial would be apreciated (I've watched the esentials videos).
Board Manager
Phil.E
Message 8 of 8 (725 Views)
12-05-2012 10:56 AM in reply to: MrNickBarker
Use [sketch>circle>extrude cut] to accurately locate holes. Use the holes for Joint Origins. Or use other geometry such as edges or corners that the Joint Origin command wants to snap to.
Phil Eichmiller
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
