Inventor Fusion
russ
Message 1 of 5 (481 Views)
Accepted Solution
Opened Inventor 2012 IPT, no sketches
481 Views, 4 Replies
03-03-2013 09:21 AM
I have a fairly complex ipt file created with Inventor 2012 for Windows.  It opened successfully but it doesn't seem to contain any sketches.  Is this expected behavior?  Is there a way to fix this?
-Russ
Board Manager
Phil.E
Message 2 of 5 (451 Views)
Re: Opened Inventor 2012 IPT, no sketches
03-07-2013 06:02 PM in reply to: russ
Fusion does not import Inventor sketches, only bodies.
Are you using Inventor Fusion for Mac?
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Autodesk, Inc.
russ
Message 3 of 5 (424 Views)
03-15-2013 12:04 PM in reply to: Phil.E
Hi Phil,
Yes, I'm using Inventor Fusion for Mac, importing from Autodesk Inventor Professional 2012 on Windows.  I'm wondering how useful the import is if I lose my sketches.  It seems I would not be able to modify the drawing in Fusion for the Mac if the sketches are gone.  Am I missing something?
Either way, I'm just so glad to have a product of this level avalable on the Mac.  I'm one program away from No More Windows.  :-)
-Russ
Board Manager
Phil.E
Message 4 of 5 (420 Views)
03-15-2013 04:07 PM in reply to: russ
Thanks for using Fusion on the Mac!
Fusion is a direct modeler, rather than parametric like Inventor. The two products, despite both being 3D modelers, are intended to work completely differently, each solving problems according to it's strengths.
In Inventor your sketch drives the shape: Edit the sketch, the shape is rebuilt with the changes. This is done with parameters: saved numerical input, to put it simply. Fusion, by being a direct modeler allows trouble free direct editing. Just grab a face and move it where you want. No parametric relationships to navigate or failed "down-browser" features.
So to answer your concern about editing in Fusion: try out the Press-pull or Tweak faces commands!
As for moving off of windows: Have you seen the Fusion 360 site? This is the next step for Fusion and it's in beta right now. Have a look! (feel free to sign up for the beta)
Phil Eichmiller
Autodesk, Inc.
russ
Message 5 of 5 (410 Views)
03-17-2013 07:45 AM in reply to: Phil.E
Hi Phil,
Thank you for the most excellent answer.  I hadn't really understood the fundamental difference between the two approaches, but you made it clear.  It then makes sense not to import sketches.  I assume I could have built exactly the same model at least as easily (relatively) in Fusion as in Inventor.  Great!
I'll take a closer look at Fusion 360.  Anything that gets me further from Windows is a plus.
-Russ
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
