• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    russ
    Opened Inventor 2012 IPT, no sketches
    217 Views, 4 Replies
    03-03-2013 09:21 AM
    I have a fairly complex ipt file created with Inventor 2012 for Windows.  It opened successfully but it doesn't seem to contain any sketches.  Is this expected behavior?  Is there a way to fix this?
    -Russ
    Please use plain text.
    Employee
    Phil.E
    Re: Opened Inventor 2012 IPT, no sketches
    03-07-2013 06:02 PM in reply to: russ
    Fusion does not import Inventor sketches, only bodies.
    Are you using Inventor Fusion for Mac?
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    russ
    03-15-2013 12:04 PM in reply to: Phil.E
    Hi Phil,
    Yes, I'm using Inventor Fusion for Mac, importing from Autodesk Inventor Professional 2012 on Windows.  I'm wondering how useful the import is if I lose my sketches.  It seems I would not be able to modify the drawing in Fusion for the Mac if the sketches are gone.  Am I missing something?
    Either way, I'm just so glad to have a product of this level avalable on the Mac.  I'm one program away from No More Windows.  :-)
    -Russ
    Employee
    Phil.E
    03-15-2013 04:07 PM in reply to: russ
    Thanks for using Fusion on the Mac!
    Fusion is a direct modeler, rather than parametric like Inventor. The two products, despite both being 3D modelers, are intended to work completely differently, each solving problems according to it's strengths.
    In Inventor your sketch drives the shape: Edit the sketch, the shape is rebuilt with the changes. This is done with parameters: saved numerical input, to put it simply. Fusion, by being a direct modeler allows trouble free direct editing. Just grab a face and move it where you want. No parametric relationships to navigate or failed "down-browser" features.
    So to answer your concern about editing in Fusion: try out the Press-pull or Tweak faces commands!
    As for moving off of windows: Have you seen the Fusion 360 site? This is the next step for Fusion and it's in beta right now. Have a look! (feel free to sign up for the beta)
    Phil Eichmiller
    russ
    03-17-2013 07:45 AM in reply to: Phil.E
    Hi Phil,
    Thank you for the most excellent answer.  I hadn't really understood the fundamental difference between the two approaches, but you made it clear.  It then makes sense not to import sketches.  I assume I could have built exactly the same model at least as easily (relatively) in Fusion as in Inventor.  Great!
    I'll take a closer look at Fusion 360.  Anything that gets me further from Windows is a plus.
    -Russ
