Hi all,
Trying to figure out exactly how to make something like this:
In making this, I'd like to be able to do a few things I can't figure out:
1) move points where edges join (once 3d)
2) create the "overhang" of the rail around the top edge
3) If possible, add a subtle wood texture (actual geometry... not critical)
Any help appreciated!
thanks,
Andrew
Solved by SallyYang. Go to Solution.
For issue1, we cannot support it as Fusion is a direct modeling tool, this could be supported in parametric modeling tools, such as Inventor.
For Issue2, currently you cannot do this with a simple step, however, we will consider to support it in future releases.
For issue3, you can apply wood materil to the body/components.
Please get the 2 verions of modeling method from attachment, I think the first one is much closer to your description.
Attach the f3d file of second version.
