Inventor Fusion
Member
ckasunic
Message 1 of 2 (409 Views)
Need Help Converting Mesh into Solid/Surface
409 Views, 1 Replies
04-15-2013 11:11 AM
I have a model in Autodesk Inventor Fusion 2013 that was imported from Google Sketchup. The model says that it is only a mesh. How can i convert the model into either a solid, or a series of solid faces?? Any help in much appreciated!
Board Manager
Phil.E
Message 2 of 2 (340 Views)
Re: Need Help Converting Mesh into Solid/Surface
05-21-2013 03:27 PM in reply to: ckasunic
There likely isn't a way to convert it. Fusion allows such import for reference purposes.
Is there some way to get the same file exported from Sketchup as another file type, or with some option that doesn't produce only  a mesh?
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
