• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Distinguished Contributor
    Multiples commands on Menu File
    354 Views, 3 Replies
    11-05-2009 04:31 AM
    After installed the Fusion Preview 2 and Manager, in Inventor 2010 Pro with SP1.
    When IPT files is open, appear multiples commands "Open DWG" in my Menu File.
    Follow attach.
    Cristiano Oliveira
    Autodesk Certified
    http://managermachine.blogspot.com
    Please use plain text.
    Employee
    Re: Multiples commands on Menu File
    11-23-2009 11:41 PM in reply to: cristiano.oliveira
    Thanks for the feedback.We have reported this problem to our development and it is on track.
    The problem occurs under Inventor Clissic UI and it is OK under Ribbon UI.You can work around it by changing Inventor UI to Ribbon UI and back to classic UI.
    -Huan
    Employee
    11-24-2009 07:14 PM in reply to: cristiano.oliveira
    More info:
    You may delete the PartFileMenu folder in Windows Registry editor here to get rid of the multiples commands "Open DWG" in Classic UI: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion14.0\UI Customization V5\ToolBars\PartFileMenu
    It is also suggested to use Change Manager in Ribbon UI before the problem is resolved.
    -Huan
    11-25-2009 02:39 AM in reply to: cristiano.oliveira
    Thank You Huan. I change the UI. Now is correct.
    Cristiano Oliveira
    Autodesk Certified
