Inventor Fusion
- Start Article
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Multiple saved 'views' for exploded diagrams
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi Everyone,
I posted up a while ago about woodshop cut lists and and exploded diagrams and a rep from Autodesk said they're working on it for mid-year. Which is GREAT! Veyr much looking forward to that. In the mean time, however, I'm just manually pulling apart models and dimensioning them in different views. This does work... but it'd be great to not have to save a different file for each parts view. I've tried creating a 'named view,' but that only allows me to save a particular perspective view. As far as I've found.
Basically what I want to do is have a couple different views saved that have the fully assembled piece, and a view where I've moved all the parts away from each other and dimmensioned them invididually. Basically doing a manual parts diagram.
Is there a feature that allows soething like that?
Thanks.
Re: Multiple saved 'views' for exploded diagrams
- Highlight
- Email to a Friend
Thanks for using Fusion!
Can you post an image of one of your "manual" exploded views? I need to get an idea of what you are trying to accomplish.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Autodesk, Inc.
- Highlight
- Email to a Friend
Sure,
This is basically what I'm getting at. Having all the parts I"m working with blown apart so it's easier to see the individual part dimensions and such. And at a quick glance have an idea of where everything goes.
In order for me to accomplish this I had to resave the document to a seperate file with all of the pieces moved apart. Ideally I'd like to have one file with multiple 'views' or something so I can have the fully assembled project in one, and the blown up view in another and switch back and forth between the two.
Thanks.
- Highlight
- Email to a Friend
Thanks! Nice work.
I do not have an update for the exploded view solution, but I can offer a work around that keeps it all in one file:
- New file
- New component on root, call it Assembly
- Make all parts as sub components to this
- New component on root, call it Exploded
- Copy and paste the assembly components to Exploded, do not use Paste New, just Paste.
- You can move the pasted assembly with the triad that appears
- You can then pull apart Exploded and use the visibility toggles + saved views to manage the views.
- When you update a part dimension, the exploded parts will update
I know it's not ideal, but please let us know if it helps any!
-Phil
Phil Eichmiller
Autodesk, Inc.
- Highlight
- Email to a Friend
Excellent. Not a perfect (i.e. painless and automated) solution. But That'll work very well in the meantime. I had another post about a 'shop drawings' feature and the gentleman who replied to that said it's actually a feature that is in the works. So that'll be great too.
I'm guessing that as a woodworker I'm probably in the minority when using a program like fusion, but having used solidworks and a couple of animation modeling apps in the past, sketchup is just so... weirdly setup and annoying. Thanks for all the help!
