Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Mechanical Desktop 2005 to Inventor Fusion 2012
3 REPLIES 3
TrackOgre
728 Views, 3 Replies
So they've updated things at work finally and now I need to figure out how to import my MDT files into Inventor Fusion 2012.  What direction or clues can you provide help with.  This seems like a big jump in software to me.  Thanks!
3 REPLIES 3
bobvdd
in reply to: TrackOgre
You can't get MDT files directly into Fusion. You will have to make a detour via Inventor.
Assuming that you installed Fusion as part of the Autodesk® Product Design Suite 2012, I think the only thing you need to do is download the MDT version that is compatible with Inventor 2012 release from www.autodesk.com/mdt
Import your MDT dwg into Inventor first. Then open the resulting IAM files in Fusion.
Good luck.
Bob
Bob Van der Donck
Principal UX designer DMG group
schneik-adsk
Is there a reason why you want to go to Invento Fusion and not Inventor?
-Kevin Schneider
Kevin Schneider
TrackOgre
in reply to: schneik-adsk
Fusion is what they installed on my machine along with some Autocad stuff.  I wasn't involved in their selection process and frankly am not up to date on the features of the current offerings.  I will need to find out exactly what package they purchased and determine if I can just have Inventor which sounds like what I should want.  Stay tuned.
Chuck Bunnell
