Inventor Fusion
Active Member
Message 1 of 10 (697 Views)
Inventor - Split an object
697 Views, 9 Replies
02-18-2013 03:04 AM
I wonder if it is possible to split an object when I open a dwg-file in Inventor Fusin? .eg. split a wall in two parts..?
what other programs can be used to split objects easily?
Kind regards,
Board Manager
Phil.E
Message 2 of 10 (660 Views)
Re: Inventor - Split an object
02-22-2013 11:53 AM in reply to: Niloofar54
You can try the Split command. See image.
(Please mark this response as "Accept as Solution" if it answers your question)
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Active Member
Message 3 of 10 (646 Views)
02-24-2013 11:52 PM in reply to: Niloofar54
Thanks for your help,
But it does not seem to work when I open a dwg file and want to split one of the objects. but it works when I draw an object in Inventor and then want to split it...
Board Manager
Phil.E
Message 4 of 10 (643 Views)
02-25-2013 10:36 AM in reply to: Niloofar54
Can you post a dwg file with this issue? Thanks!
Phil Eichmiller
Active Member
Message 5 of 10 (632 Views)
02-25-2013 10:32 PM in reply to: Niloofar54
Please see attached file, it's a .dwg
I want to know if I can split a wall or a slab easily...?
thanks,
Board Manager
Phil.E
Message 6 of 10 (625 Views)
02-26-2013 11:25 AM in reply to: Niloofar54
Thanks for the file.
Unfortunately I could not open it in Inventor Fusion 2013. Is this the version you are using?
Also, I'm curious what your intent is. Do you wish to edit a .dwg 2D drawing file and then save it as a .dwg 2D drawing file (sort of like a replacement for AutoCAD). Or do you intend to create 3D shapes from your floor plan and output a 3D .dwg Fusion file?
Phil Eichmiller
Active Member
Message 7 of 10 (610 Views)
02-27-2013 11:00 PM in reply to: Niloofar54
Yes, I use Inventor Fusion 2013.
What my group need to do is to split an object in NavisWork, which is impossible. someone said  it's possible to do it in inventor fusion. but it does not work there either.
eg consultants have designed a wall that is 25 m long in their model, but we want to split it according to our construction planning.
best regards
Niloofar
Board Manager
Phil.E
Message 8 of 10 (606 Views)
02-28-2013 09:27 AM in reply to: Niloofar54
Fusion has a sketch trim tool. See attached image.
Phil Eichmiller
Active Member
Message 9 of 10 (596 Views)
03-01-2013 04:41 AM in reply to: Niloofar54
We don't want to Trim a sketch,
why can't we split an object on a dwg file in Inventor?  Does it really need to be a drawn object in Inventor which can be split?
regards
N
Board Manager
Phil.E
Message 10 of 10 (591 Views)
03-01-2013 09:25 AM in reply to: Niloofar54
Can you open the file in Inventor Fusion? Each time I try there is no information Inventor Fusion can display.
I can open the file in AutoCAD and all edits are possible. Have you tried AutoCAD?
http://usa.autodesk.com/autocad/
Phil Eichmiller
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
