• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Active Member
    Inventor - Split an object
    284 Views, 9 Replies
    02-18-2013 03:04 AM
    I wonder if it is possible to split an object when I open a dwg-file in Inventor Fusin? .eg. split a wall in two parts..?
    what other programs can be used to split objects easily?
    Kind regards,
    Please use plain text.
    Employee
    Phil.E
    Re: Inventor - Split an object
    02-22-2013 11:53 AM in reply to: Niloofar54
    You can try the Split command. See image.
    (Please mark this response as "Accept as Solution" if it answers your question)
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Autodesk, Inc.
    Active Member
    02-24-2013 11:52 PM in reply to: Niloofar54
    Thanks for your help,
    But it does not seem to work when I open a dwg file and want to split one of the objects. but it works when I draw an object in Inventor and then want to split it...
    Employee
    Phil.E
    02-25-2013 10:36 AM in reply to: Niloofar54
    Can you post a dwg file with this issue? Thanks!
    Phil Eichmiller
    Autodesk, Inc.
    Active Member
    02-25-2013 10:32 PM in reply to: Niloofar54
    Please see attached file, it's a .dwg
    I want to know if I can split a wall or a slab easily...?
    thanks,
    Employee
    Phil.E
    02-26-2013 11:25 AM in reply to: Niloofar54
    Thanks for the file.
    Unfortunately I could not open it in Inventor Fusion 2013. Is this the version you are using?
    Also, I'm curious what your intent is. Do you wish to edit a .dwg 2D drawing file and then save it as a .dwg 2D drawing file (sort of like a replacement for AutoCAD). Or do you intend to create 3D shapes from your floor plan and output a 3D .dwg Fusion file?
    Phil Eichmiller
    Autodesk, Inc.
    Active Member
    02-27-2013 11:00 PM in reply to: Niloofar54
    Yes, I use Inventor Fusion 2013.
    What my group need to do is to split an object in NavisWork, which is impossible. someone said  it's possible to do it in inventor fusion. but it does not work there either.
    eg consultants have designed a wall that is 25 m long in their model, but we want to split it according to our construction planning.
    best regards
    Niloofar
    Employee
    Phil.E
    02-28-2013 09:27 AM in reply to: Niloofar54
    Fusion has a sketch trim tool. See attached image.
    Phil Eichmiller
    Autodesk, Inc.
    Active Member
    03-01-2013 04:41 AM in reply to: Niloofar54
    We don't want to Trim a sketch,
    why can't we split an object on a dwg file in Inventor?  Does it really need to be a drawn object in Inventor which can be split?
    regards
    N
    Employee
    Phil.E
    03-01-2013 09:25 AM in reply to: Niloofar54
    Can you open the file in Inventor Fusion? Each time I try there is no information Inventor Fusion can display.
    I can open the file in AutoCAD and all edits are possible. Have you tried AutoCAD?
    http://usa.autodesk.com/autocad/
    Phil Eichmiller
    Autodesk, Inc.
