Inventor Fusion
Message 1 of 3 (332 Views)
Inventor Fusion .net framework crash
332 Views, 2 Replies
08-21-2011 10:18 PM
Hello Autodesk,
i have a problem with Inventor Fusion TP 3 build 0.3.0.29.
Whenever i want to open a dokument, i get following error: look at the attachement.
Reistalling isn't fixing the problem.
I even set up a new pc with win7x64 (former Vistax64), the same error.
I think it happens after a few windows updates.
Any hints or solutions?
muzist
Employee
Message 2 of 3 (310 Views)
Re: Inventor Fusion .net framework crash
08-22-2011 08:41 PM in reply to: mzmeister
Sorry that you encountered problems. It seems it once worked without problem. Then I would suggest you also to try re-installing .Net Framework 3.5 SP1 and you can download it from http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=25150
Also I have a few questions:
  1. Are you using German Fusion on a German Win7_64 system?
  2. Are you trying to open Fusion DWG files or files with other formats?Say Inventor file,STEP file,etc.?
Thank you for more info.
-Huan
Autodesk,Inc
Message 3 of 3 (302 Views)
08-22-2011 10:17 PM in reply to: Huan.Yu_Autodesk
Hello Huan,
just figured it out by myself. The problem was a broken windows user-profile. I deleted the profile from pc and server an added a new user and everything works fine.
Thanks for thinking bout my problem
MzMeister
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
