Hello Autodesk,
i have a problem with Inventor Fusion TP 3 build 0.3.0.29.
Whenever i want to open a dokument, i get following error: look at the attachement.
Reistalling isn't fixing the problem.
I even set up a new pc with win7x64 (former Vistax64), the same error.
I think it happens after a few windows updates.
Any hints or solutions?
muzist
Sorry that you encountered problems. It seems it once worked without problem. Then I would suggest you also to try re-installing .Net Framework 3.5 SP1 and you can download it from http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=25150
Also I have a few questions:
Thank you for more info.
-Huan
Autodesk,Inc
Hello Huan,
just figured it out by myself. The problem was a broken windows user-profile. I deleted the profile from pc and server an added a new user and everything works fine.
Thanks for thinking bout my problem
MzMeister
