• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Inventor Fusion 2013 Will Not Load
    777 Views, 17 Replies
    07-24-2012 09:46 AM
    Fusion 2013 will not load regardless of running it from within Inventor or on it's own. There is no error message. It begins to load up and then simply evacuates from memory as if it had never been run in the first place.
    I have tried to run it as administrator with no change. I have uninstalled and reinstalled it with no change.
    Inventor 2013 runs flawlessly as does the rest of my Autodesk Product Design Suite.
    Any help would be greatly appreciated.
    Please use plain text.
    Employee
    Phil.E
    Re: Inventor Fusion 2013 Will Not Load
    07-27-2012 02:15 PM in reply to: engineer968
    Is this the first installation of Fusion on this machine? Did you have Product Design Suite 2012 or a Fusion technical preview installed previously?
    Phil Eichmiller
    Quality Assurance Team
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Autodesk, Inc.
    Active Member
    08-01-2012 03:28 AM in reply to: engineer968
    I have the same....:smileysad:
    Few days was OK ( if I can say 1 crash per hour is OK...) but now crash on splash screen... Reinstallation won't to help...
    New Member
    08-01-2012 09:08 AM in reply to: engineer968
    Hi !
    Have the same problem - Inventor Fusion 2013 hangs during installation, never loads...what can I do ?
    How do I remove it ?
    Employee
    Phil.E
    08-01-2012 09:19 AM in reply to: Duohsoft
    kovir, and Duosoft,
    Phil Eichmiller
    Autodesk, Inc.
    New Member
    08-01-2012 09:47 AM in reply to: engineer968
    Hi !
    Yes... I re-started my Mac (OSX Lion), went to Launcher and found that the installation  / download had stopped.
    Re-started the download / install and was able to fullfill the installation process !
    Nice UI in IF 2013 ...
    Thanks !
    Active Member
    08-01-2012 10:19 AM in reply to: Phil.E
    Yes, this is first installation. I think it was started when I installed a trial of Autocad for Mac ( now I know that Autocad don't run on Mountain Lion...)
    Employee
    Phil.E
    08-01-2012 11:21 AM in reply to: kovir
    You should try a fresh download/install of Fusion.
    Go here to download your new copy of Fusion and try again.
    If it doesn't work, please respond with the steps you took and details about your system.
    Phil Eichmiller
    Autodesk, Inc.
    Active Member
    08-01-2012 02:58 PM in reply to: Phil.E
    Reinstallation didn't help... I have a message windows ( on splash screen) :" the last time you opened Inventor Fusion it unexpectedly quit while reopening windows. Do You want to try to reopen its windows again? ..."
    I may too choose Reopen or Don't Reopen - it crash every time.
    I reinstalled Inventor Fusion but this message apeared again...
    Active Member
    08-01-2012 02:59 PM in reply to: kovir
    Macbook Pro 7.1  Mountain Lion, 8GB RAM, CUDA 5, NVIDIA 320M
