Inventor Fusion
Member
Auxiliary
Message 1 of 11 (3,375 Views)
Importing Files into Inventor Fusion
3375 Views, 10 Replies
05-14-2011 12:35 PM
I just received Inventor Fusion with my Inventor 2012 Suite.  I am new to Fusion.  I have read about it but have never used it before.  I am able to draw in Fusion and I have opened step files.  When I try to open a solidworks 2011 part file (.sldprt), the software acts like it has opened the file but there is nothing there (it is not a sheet metal part).  I read through some help files and have not found anything special to do when opening these files.  What do I need to do to be able to open these files?  Does it have to do with the version of the files?
Employee
udayag
Message 2 of 11 (3,360 Views)
Re: Importing Files into Inventor Fusion
05-16-2011 10:16 AM in reply to: Auxiliary
Could you please send the file(s) to udaya.gunasena@autodesk.com to take a look?
Did you try opening them in Inventor 2012?
Udaya Gunasena
Fusion Development
Member
Auxiliary
Message 3 of 11 (3,346 Views)
05-16-2011 03:47 PM in reply to: udayag
Inventor 2012 would not open the files.  It gave an error on the Autodesk Inventor Translation Report.  I have attached the files that I am trying to open.
Employee
Angie.JieLi_Autodesk
Message 4 of 11 (3,273 Views)
05-26-2011 08:34 PM in reply to: Auxiliary
It does relate to the file version, your file version is Solidwork 2011,  Fusion 2012 and Inventor 2012 don't support opening this version of sldprt, it supports version up to Solidwork 2010.
If you have Solidwork installed, Would you please try to use Solidwork to save it to IGES/STEP, then open with Fusion or Inventor.
-Angie Li
New Member
vutsis
Message 5 of 11 (2,988 Views)
08-25-2011 06:41 AM in reply to: Auxiliary
I am trying to import SolidWorks 2010 files.  Inventor 2012 will see the preview of the model, but after it imports the file there is nothing on the screen.   Any help will be greatly apreciated.  The import traslation report shows a succesfull translation; however, individual parts are not found.
Employee
Wendy.Chen_Autodesk
Message 6 of 11 (2,971 Views)
08-25-2011 11:51 PM in reply to: vutsis
Hi, vutsis,
Many thanks for reporting the issue. Do you import the files to Inventor Fusion 2012?  if yes, and there is nothing on the screen, It did have something wrong. Here, to better reproduce your issues, could you please attach your file? or you can send it to me: Chunping.chen@autodesk.com. Thus we will have a try. and give you feedback.
Best Regards,
Wendy
Wendy Chen
Fusion 360 Team
JDMather
Message 7 of 11 (2,892 Views)
09-25-2011 09:52 AM in reply to: vutsis
Attach the original file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
pleonor
Message 8 of 11 (2,844 Views)
10-06-2011 02:54 PM in reply to: JDMather
good evening,
I have the same problem that the person before. I receive an .STEP format from a customer (I think that it comes from CATIA v5), but when I open it with Iventor Fusion 2012, it reconize the menu, but there is nothing on screen.
I tryed also with the same document in IGES, but after a while trying to open, inventor gives me an error message and can not open it.
Can anyone help me with this?
JDMather
Message 9 of 11 (2,801 Views)
10-13-2011 02:08 PM in reply to: pleonor
Can you attach the fle here?
vidjeane
Message 10 of 11 (1,039 Views)
07-06-2013 01:00 AM in reply to: JDMather
Me too have the same problem.
Fusion selection dialog box selects the part, but nothing on the screen.
is there any solution?
part attached.
Vidjeane.M
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
