i have some trouble with importing *.stp files into inventor fusion on windows & mac. Ok, when i try to import the file to Fusion 2013 it only shows me some lines and edges but not the complete model. Then i tried it in Fusion 2012 but here it shows me nothing. The last one i tried was Fusion for Mac and it worked perfect, the *.stp File was shown complete but one little strange failure exists again, the model was in the original file 120mm but in fusion it shows 1200mm. Is there a way to fix this problem with the measure? because when i save it the size is the same and in this size i cant simulate it in Moldflow.
thank you.
Would it be possible for you to post the file? If you cannot publicly do so, can you send via email?
i cant publish the file due to the directives of our client. But email should be ok. Can you send me your email adress?
Hi
Could you send it to me?
Email: Cathy.wang@autodesk.com
Cathy
Autodesk, Inc
