• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Dakar23
    Import .stp File into Fusion
    268 Views, 3 Replies
    09-26-2012 06:37 AM
    i have some trouble with importing *.stp files into inventor fusion on windows & mac. Ok, when i try to import the file to Fusion 2013 it only shows me some lines and edges but not the complete model. Then i tried it in Fusion 2012 but here it shows me nothing. The last one i tried was Fusion for Mac and it worked perfect, the *.stp File was shown complete but one little strange failure exists again, the model was in the original file 120mm but in fusion it shows 1200mm. Is there a way to fix this problem with the measure? because when i save it the size is the same and in this size i cant simulate it in Moldflow.
    thank you.
    Please use plain text.
    Employee
    Phil.E
    Re: Import .stp File into Fusion
    09-26-2012 09:20 AM in reply to: Dakar23
    Would it be possible for you to post the file? If you cannot publicly do so, can you send via email?
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Autodesk, Inc.
    Member
    Dakar23
    09-26-2012 10:32 PM in reply to: Phil.E
    i cant publish the file due to the directives of our client. But email should be ok. Can you send me your email adress?
    Employee
    09-28-2012 07:11 PM in reply to: Dakar23
    Hi
    Could you send it to me?
    Email: Cathy.wang@autodesk.com
    Cathy
    Autodesk, Inc
