• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    ab
    New Member
    I doubt that Inventor Fusion will succeed, on less...
    186 Views, 0 Replies
    10-03-2009 02:31 PM
    Inventor Fusion seams like a tool with a lot of freedom, as CAD-Application Engineer I see this both as a strength and a weakness. So here´s my input which could solve this issue. If inventor Fusion get´s to work a bit like Inventor Pipe, where it is possible to do dimension/parameters in relation to an increement/tolerance table there would be both freedom and control. One table for angular parameters and one for directional. The function could work like a drop down list with increements rounding of the dimensions while adding them. The increement table should appear only when selected, otherwise it should just remenber the last used increement.
    It should also be possible turn of the increment table and it should also to custom increments to the the default table.
    If this very basic method will be added to the workflow, I think that the users will be accept the dynamic way of moddeling, otherwise i doubt that Inventor Fusion will succeed.
    Best regards
    Anders Bang - NTI-CADcenter A/S
    - is this the right place to add this input, or is there an Invetor Fusion wishlist somwhere?
    Please use plain text.
