Inventor Fusion
New Member
Ice7Shadow
Message 1 of 4 (2,288 Views)
How do I merge 2 solid bodies into 1 in Inventor Fusion 2013?
2288 Views, 3 Replies
05-08-2013 07:15 AM
I am struggling to find an answer to that simple question. I realized I can't find the option in Inventor Fusion 2013 which would allow to create 1 solid body out of 2 without any splits, fringes, nothing that will show that previously it's been 2 separate bodies. Maybe screenshots would be helpful. Please help me to sort this out. Thank you.
Board Manager
Phil.E
Message 2 of 4 (2,221 Views)
Re: How do I merge 2 solid bodies into 1 in Inventor Fusion 2013?
05-21-2013 03:38 PM in reply to: Ice7Shadow
If these are separate components you can use the boolean command.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Valued Contributor
stephenson513
Message 3 of 4 (1,204 Views)
02-24-2014 11:52 PM in reply to: Phil.E
How do you merge separate solid bodies and keep their existing colors? I have a part that's half half
Board Manager
Phil.E
Message 4 of 4 (1,193 Views)
02-25-2014 08:00 AM in reply to: stephenson513
In order for different materials to be applied on one body or component there should be an edge of some kind. So any face will take a new material, right up to it's boundary edges.
If you need to create edges, use the Split Face command. First sketch a line as a cutting tool, then use Split Face to cut the face where the line is. Material can be applied differently on either side of the split.
Phil Eichmiller
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
