I am trying without much success to duplicate a sketch, modify it and apply to another surface. What is the right way to do this?
I have also tried to "project" the sketch against another's component surface, but it doesn't seem to do what it should, as the sketch remais on the same surface/component
Franklin Dattein
Hi, thanks for posting!
Inventor Fusion 2013 does not have a copy command for sketches.
A method you might use is to copy features and paste them onto other faces.
Can you post a screen grab showing the Project Geometry issue you are having?
Thanks!
