Inventor Fusion
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Help! Importing .DWG Files in Inventor Doesn't Work For Me
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Marco:
Thank you for your reply once again, but:
Even though I downloaded my previous version of Inventor Fusion only one week ago, I uninstalled it (along with the Autodesk DWG plug-in that came with it) before I downloaded the latest version from the link you provided.
When I launched the Autodesk_Inventor_Fusion_2013_Win_32bit.exe installer, I did not see the Inventor Fusion plug-in option that was on the screenshot that you provided - only the Autodesk Inventor Fusion 2013 was there.
Now, I have the latest version that still has the same problem (I tested it twice just to be sure) and I also noticed that now I don't have the Autodesk DWG plug-in that I removed before installing the latest version from your link.
Can you provide a solution as to why this is happening?
Thank you.
Tom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Tom,
That's my fault. I thought there would be a plug-in for AutoCAD in that installer, while it turns out that's not the case. My apologize!
Are you still able to get the previous installer(contains the plug-in for AutoCAD)? If yes, you can just run to install the plug-in again, and then please share a video of what you did with me. I'll look into that.
You can attach it here or mail to me at: LiangDOTLiu@autodeskDOTcom directly if you want.
Macro Liu
Inventor Fusion QA Team
(Please make this response as "Accept as Solution" if it answers your question.)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello, Marco!
Thank you again for sticking with me through this problem. I really appreciate it.
Well, I am glad that is was not something I did wrong. Unfortunately, no, I don't have the previous installer. Would it be possible if you were to email that plug-in directly to me or post it here?
I will send you a copy of this post with my email included.
As for posting a video, I don;t have the software to make videos so I can't send you one, unfortunately.
Thank you!
Tom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks to your help in your email to me, my problem has been solved.
Thank you very much, Maro! ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Maro or Tom,
I got the same problem, maybe you can post the solution here?
Thank you
Martijn
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Martijn:
I have tried to attached a video that Marco was kind enough to email to me but unfortunately it is in a .SWF format and for some bizarre reason, this forum can't accept that file type. Maybe if you contact Marco, he can send it to you.
But here are the steps that are shown in the video:
If you open your DWG file in AutoCAD:
1. select the shape
2. COPY the shape to your clipboard
3. Go to Inventor Fusion
4. Choose the Create New Sketch command
5. Then paste the shape and it should appear.
I didn't do step number 4. (Create New Sketch) and because of that, when I pasted the shape into a totally blank Inventor Fusion window, nothing appeared for me.
In every other software application I have used, if you paste something that is on your clipboard, it will appear but that isn't the case with Inventor Fusion.
Maybe there is some reason that the tech people have set it up this way but it was quite frustrating that you have to go through this very non-intuative step to paste something.
I hope this helps, Martijn. Good luck!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The size of the video is a little large for the forum and it can't be attached here.
While you should be able to do that if you follow the 5 steps in Tom's reply. And as indicated by Tom, 'Create New Sketch' is a key step here. This is to ensure you to copy the objects to the plane you want.
Macro Liu
