Inventor Fusion
Member
Sarz91
Message 1 of 11 (549 Views)
Having trouble with Inventor Fusion.
549 Views, 10 Replies
09-02-2012 10:34 AM
I recently downloaded the student edition of Simulation CFD. Inventor Fusion came with it. I use Creo 2.0 for most of my college work and also have it donwloaded on my computer. My problem is anytime I try and open one of the Creo 2.0 files in Fusion, it either crashes or freezes. I can open the sample model no problem but then when I try to run some tests on it in Simulation CFD that program becomes unresponsive.
I only just built up my system about a month or two ago.
I'll list the specs anyway:
-CPU: I5 3570K overclocked to 4.2 GHz
-Ram: 16 GB ddr3
-GPU: GTX 670
-PSU: 650 Watt Amazon Super Flower
-Primary Memory Storage unit: Samsung 830 series 128GB
-Secondary Memory Storage unit: Seagate Barracuda 7200 rpm 1TB
I've uninstalled and re installed a few times. Any help would be greatly appreciated.
Employee
Mike.Zhang
Message 2 of 11 (527 Views)
Re: Having trouble with Inventor Fusion.
09-03-2012 01:42 AM in reply to: Sarz91
Could you tell me which OS you are using now to run it?
Win7-64bit OS or Win7-32bit OS?
And could you send me your models which opened in Fusion?
You can attach them here or mail to me:
jiangang.zhang@autodesk.com
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
New Member
alper
Message 3 of 11 (516 Views)
09-03-2012 08:40 AM in reply to: Sarz91
I have same problem, system
İmac
21.5-inch, Mid 2010
3,06 GHz Intel Core i3
8 GB 1333 MHz DDR3
ATI Radeon HD 4670 256 MB
OS X 10.8.1 (12B19)
Member
Sarz91
Message 4 of 11 (512 Views)
09-03-2012 10:44 AM in reply to: Mike.Zhang
My OS is Win 7 64 bit. I sent you the model. Its just a rectangular shaped solid. I can open the part in fusion using the NX translator but the part doesn't appear and Fusion closes shortly after. If I try the ProE translator I get the following error message and then Fusion instantly closes Error: Unhandled Exception. I can open the sample model with Fusion but when I bring it across into simulation CFD both programs become unresponsive and close.
Employee
Mike.Zhang
Message 5 of 11 (503 Views)
09-03-2012 07:18 PM in reply to: Sarz91
Hi Sarz91,
Tanks your replyment, we'll analyze it.
I haven't recieved your mail with model now, could you attach the model here?
Mike.Zhang
SQA Engineer
Autodesk, Inc.
*Expert Elite*
JDMather
Message 6 of 11 (487 Views)
09-04-2012 09:21 AM in reply to: Mike.Zhang
Does Fusion support Creo 2 (or only Creo 1)?
I tried a Creo 2 file and Fusion 2013 crashed here as well.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Employee
Mike.Zhang
Message 7 of 11 (474 Views)
09-04-2012 11:09 PM in reply to: Sarz91
Fusion doesn't support Creo files.
You can find the detail information here.
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013/Help/0167-Import_D167
Mike.Zhang
SQA Engineer
Autodesk, Inc.
*Expert Elite*
JDMather
Message 8 of 11 (467 Views)
09-05-2012 05:26 AM in reply to: Mike.Zhang
Mike did you try it?
Fusion imports Creo 1.0 files on my machine just fine.
The Inventor Help files are out-of-date (as usual for Autodesk).
Creo Parametric  is the new name of Pro/Engineer.
Creo 2.0 came out after Fusion 2013, but Creo 1.0 files translate fine.
You can try it yourself with the attached Creo file.
Employee
Mike.Zhang
Message 9 of 11 (449 Views)
09-05-2012 10:33 PM in reply to: JDMather
Thanks your replyment.
Yes, I also can open your Creo 1.0 file by using Fusion 2013.
Seems the file type of Creo1.0 file is same/similar as Proe4.0 file. So we can luckly open it by Fusion 2013.
But Fusion just clarified it supports Proe file type up to version 4.0.
Types of Pro/ENGINEER files you can import:
  • *.prt* (part) (up to version 4.0)
  • *.asm* (assembly) (up to version 4.0)
  • *.g (Granite) (up to version 5.0)
Mike.Zhang
SQA Engineer
Autodesk, Inc.
Member
Sarz91
Message 10 of 11 (441 Views)
09-06-2012 05:10 AM in reply to: Mike.Zhang
So Fusion 2013 doesn't support Creo 2.0 parts? Is it the same with Simulation CFD?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
