Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Having trouble with Inventor Fusion.
10 REPLIES 10
Message 1 of 11
849 Views, 10 Replies
I recently downloaded the student edition of Simulation CFD. Inventor Fusion came with it. I use Creo 2.0 for most of my college work and also have it donwloaded on my computer. My problem is anytime I try and open one of the Creo 2.0 files in Fusion, it either crashes or freezes. I can open the sample model no problem but then when I try to run some tests on it in Simulation CFD that program becomes unresponsive.
I only just built up my system about a month or two ago.
I'll list the specs anyway:
-CPU: I5 3570K overclocked to 4.2 GHz
-Ram: 16 GB ddr3
-GPU: GTX 670
-PSU: 650 Watt Amazon Super Flower
-Primary Memory Storage unit: Samsung 830 series 128GB
-Secondary Memory Storage unit: Seagate Barracuda 7200 rpm 1TB
I've uninstalled and re installed a few times. Any help would be greatly appreciated.
10 REPLIES 10
Message 2 of 11
Mike.Zhang
Could you tell me which OS you are using now to run it?
Win7-64bit OS or Win7-32bit OS?
And could you send me your models which opened in Fusion?
You can attach them here or mail to me:
jiangang.zhang@autodesk.com
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 11
I have same problem, system
İmac
21.5-inch, Mid 2010
3,06 GHz Intel Core i3
8 GB 1333 MHz DDR3
ATI Radeon HD 4670 256 MB
OS X 10.8.1 (12B19)
Message 4 of 11
in reply to: Mike.Zhang
My OS is Win 7 64 bit. I sent you the model. Its just a rectangular shaped solid. I can open the part in fusion using the NX translator but the part doesn't appear and Fusion closes shortly after. If I try the ProE translator I get the following error message and then Fusion instantly closes Error: Unhandled Exception. I can open the sample model with Fusion but when I bring it across into simulation CFD both programs become unresponsive and close.
Message 5 of 11
Mike.Zhang
Hi Sarz91,
Tanks your replyment, we'll analyze it.
I haven't recieved your mail with model now, could you attach the model here?
Mike.Zhang
SQA Engineer
Autodesk, Inc.
Message 6 of 11
JDMather
Does Fusion support Creo 2 (or only Creo 1)?
I tried a Creo 2 file and Fusion 2013 crashed here as well.
Message 7 of 11
Mike.Zhang
Fusion doesn't support Creo files.
You can find the detail information here.
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013/Help/0167-Import_D167
Mike.Zhang
SQA Engineer
Autodesk, Inc.
Message 8 of 11
JDMather
Mike did you try it?
Fusion imports Creo 1.0 files on my machine just fine.
The Inventor Help files are out-of-date (as usual for Autodesk).
Creo Parametric  is the new name of Pro/Engineer.
Creo 2.0 came out after Fusion 2013, but Creo 1.0 files translate fine.
You can try it yourself with the attached Creo file.
Message 9 of 11
Mike.Zhang
in reply to: JDMather
Thanks your replyment.
Yes, I also can open your Creo 1.0 file by using Fusion 2013.
Seems the file type of Creo1.0 file is same/similar as Proe4.0 file. So we can luckly open it by Fusion 2013.
But Fusion just clarified it supports Proe file type up to version 4.0.
Types of Pro/ENGINEER files you can import:
  • *.prt* (part) (up to version 4.0)
  • *.asm* (assembly) (up to version 4.0)
  • *.g (Granite) (up to version 5.0)
Mike.Zhang
SQA Engineer
Autodesk, Inc.
Message 10 of 11
So Fusion 2013 doesn't support Creo 2.0 parts? Is it the same with Simulation CFD?
Message 11 of 11
Mike.Zhang
Yes, maybe Fusion will support it in future.
Mike.Zhang
SQA Engineer
Autodesk, Inc.
