Inventor Fusion
Active Contributor
engineerboy
Message 1 of 2 (153 Views)
Getting Constraint to work.....
153 Views, 1 Replies
07-07-2009 07:21 PM
Has anybody got the constraint feature to work with multiple bodies (parts).
Steve
Board Manager
schneik
Message 2 of 2 (153 Views)
Re: Getting Constraint to work.....
07-08-2009 08:46 AM in reply to: engineerboy
When you use the constraint command there are two choices: Body constraints and Component constraints. Component constraints are very similar to those that you might use in Inventor assemblies and can be applied across components for the purpose of positioning.
Body constraints can be applied to a body and can force geometry on the body to keep a specific geometric relationship.
Try creating a new document and model a simple block. Make sure two side of the block are not parallel.
Next, use a parallel body constraint on these two faces and you will see the body update to keep this new relationship. Even of you use the move tool on either face and rotate, you will see both faces will move.
-Kevin Schneider
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
