Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Fusion System Requirements for Mac
10 REPLIES 10
Message 1 of 11
jpruim
2028 Views, 10 Replies
Hello, I am on a Robotics team, and we have two softwares we are using, one of which does not support OS X Lion or Mountain Lion, and Inventor Fusion on Windows machines. Are there any versions of Inventor Fusion for Mac that support 10.6? These machines would cost too much to maintain if we either used BootCamp ($200 for each, with 13 machines) or updated ($60 for 13 machines, and the MacBooks that the IT admin is completely against updating)
We do have Windows machines, but with only 2 of them, the CAD work is very slow. Not anything to rewrite over, but if there is a version, I would like to know.
Thanks in advance,
Josh.
10 REPLIES 10
Message 2 of 11
Mike.Zhang
in reply to: jpruim
Have you tried Fusion on your Mac 10.6.8 system?
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 11
atatlow
in reply to: jpruim
I also have a similar queery. I can't try it in 10.6.8 as the 'appstore' won't let me download it as I don't have a late enough version of system software. Also, the notes in the app store say if you are using a MacPro you need a MacPro 4.1 or later. Mine is a MacPro 3.1 which has dual 2.8GHz  Quad core Xeon processors which far outstrip the other models of mac used so is this really a requirement?
Message 4 of 11
Hi
Thanks for you to use Fusion.
You can download the lastest Version of Fusion here and try again.
http://labs.autodesk.com/technologies/fusion/downloadform
Cathy
Autodesk, Inc
(Please make this response as "Accept as Solution" if it answers your question.)
Cathy Wang
Software Engineer
Fusion 360 Team
Autodesk, Inc.
Message 5 of 11
schneik-adsk
in reply to: jpruim
Josh,
send me a message at kevin dot schneider at autodesk dot com.
we shold be able to get you a solution.
Kevin Schneider
Message 6 of 11
jmedinah
in reply to: jpruim
I'm on the same trouble as the rest, I would like to run Inventor Fusion on my iMac with a 10.6.8 Osx.
But applestore don't let me download as muy Os version is lower than the recomended.
Can i downoad from another place and try if the program runs??? I won't like to change to a later version of Os as everybody told me that the latest versions are less stable than the previous.
So... Is there any solution?
Message 7 of 11
As indicated by Cathy above, you can download from Autodesk Labs:
Macro Liu
Message 8 of 11
.. your download link is redirected to Apples iTunes website from where you can only go to the AppStore.
Message 9 of 11
Same problem here - the download link takes me to a page where all you can do is then goto itunes store.  Any direct URL yet?
Geo-geek, Publisher, Author
http://LocatePress.com
http://WebMappingIllustrated.com
http://actian.com/products/ingres/geospatial
Message 10 of 11
crossection235
in reply to: jpruim
That link goes to the App Store through iTunes. We need a link to download Inventor Fusion that doesn't refer to the App Store, which will not allow IF to be downloaded by a 10.6.8 OS X version.
Message 11 of 11
philip.s
in reply to: crossection235
Hello Michael,
The Mac OS X software is only available though the Mac App Store. Are you able to download onto a different machine running 10.7 or greater and transfer over?
