• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    jpruim
    Fusion System Requirements for Mac
    744 Views, 10 Replies
    09-08-2012 01:10 PM
    Hello, I am on a Robotics team, and we have two softwares we are using, one of which does not support OS X Lion or Mountain Lion, and Inventor Fusion on Windows machines. Are there any versions of Inventor Fusion for Mac that support 10.6? These machines would cost too much to maintain if we either used BootCamp ($200 for each, with 13 machines) or updated ($60 for 13 machines, and the MacBooks that the IT admin is completely against updating)
    We do have Windows machines, but with only 2 of them, the CAD work is very slow. Not anything to rewrite over, but if there is a version, I would like to know.
    Thanks in advance,
    Josh.
    Please use plain text.
    Employee
    Mike.Zhang
    Re: Fusion System Requirements for Mac
    09-10-2012 05:05 AM in reply to: jpruim
    Have you tried Fusion on your Mac 10.6.8 system?
    [Mike.Zhang]
    [SQA Engineer]
    [Fusion 360] Quality Assurance Team
    Autodesk, Inc.
    New Member
    09-25-2012 01:52 PM in reply to: jpruim
    I also have a similar queery. I can't try it in 10.6.8 as the 'appstore' won't let me download it as I don't have a late enough version of system software. Also, the notes in the app store say if you are using a MacPro you need a MacPro 4.1 or later. Mine is a MacPro 3.1 which has dual 2.8GHz  Quad core Xeon processors which far outstrip the other models of mac used so is this really a requirement?
    Employee
    09-27-2012 12:02 AM in reply to: atatlow
    Hi
    Thanks for you to use Fusion.
    You can download the lastest Version of Fusion here and try again.
    http://labs.autodesk.com/technologies/fusion/downloadform
    Cathy
    Autodesk, Inc
    (Please make this response as "Accept as Solution" if it answers your question.)
    Board Manager
    schneik
    10-03-2012 07:11 PM in reply to: jpruim
    Josh,
    send me a message at kevin dot schneider at autodesk dot com.
    we shold be able to get you a solution.
    Kevin Schneider
    New Member
    11-03-2012 05:33 AM in reply to: jpruim
    I'm on the same trouble as the rest, I would like to run Inventor Fusion on my iMac with a 10.6.8 Osx.
    But applestore don't let me download as muy Os version is lower than the recomended.
    Can i downoad from another place and try if the program runs??? I won't like to change to a later version of Os as everybody told me that the latest versions are less stable than the previous.
    So... Is there any solution?
    Employee
    12-26-2012 07:22 PM in reply to: jmedinah
    As indicated by Cathy above, you can download from Autodesk Labs:
    Macro Liu
    Member
    01-10-2013 07:17 AM in reply to: Macro.Liu_Autodesk
    .. your download link is redirected to Apples iTunes website from where you can only go to the AppStore.
    spatialguru
    01-18-2013 10:52 AM in reply to: ulrichpetschke
    Same problem here - the download link takes me to a page where all you can do is then goto itunes store.  Any direct URL yet?
    Geo-geek, Publisher, Author
    http://LocatePress.com
    http://WebMappingIllustrated.com
    http://actian.com/products/ingres/geospatial
    New Member
    01-29-2013 09:57 AM in reply to: jpruim
    That link goes to the App Store through iTunes. We need a link to download Inventor Fusion that doesn't refer to the App Store, which will not allow IF to be downloaded by a 10.6.8 OS X version.
