• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    Fusion Puzzler... Deleting a feature in the history?
    130 Views, 2 Replies
    08-09-2009 01:31 PM
    A blend of direct modeling and history based modeling sounds promising. So let’s try something. I’ve attached a simple model to illustrate.
    1) Extrude a rectangle with a tapered angle.
    2) Put a fillet on one of the angled edges
    3) Fillet the edges around the top face of the part.
    Now let’s try some fusion. I can do some direct editing, pulling faces, and changing fillet radii. Cool.
    Let’s try some history based modeling. Oops, I didn’t want the fillet on the one angled edge. (It’s fillet 2 in the example file) Let’s delete it in the history tree as IV would. Oh, oh. Can’t delete it. Can’t bring it to a radius of 0 either. Of course with a simple model I could start deleting features backwards, but on a more complicated model the fillet might be many features back.
    Ideas?
    Thanks!
    Please use plain text.
    Employee
    Re: Fusion Puzzler... Deleting a feature in the history?
    08-09-2009 03:57 PM in reply to: beekley
    Glad to hear that you're trying cases like this in Fusion.
    This is really an issue with the Fusion browser, specifically for Fillet2. There are really 2 faces that should be part of Fillet2. If you select both, you can delete them from the model. See attached picture.
    Jeff Strater (Fusion development team)
    08-10-2009 06:10 PM in reply to: beekley
    Yes Jeff, this works to remove fillet 2
