Inventor Fusion
Distinguished Contributor
mies07
Message 1 of 2 (1,019 Views)
Fusion - Open Fusion DWG - Change Manager
1019 Views, 1 Replies
01-06-2012 01:27 PM
After quite a bit of frustration, I have noticed these behaviors for my installation:
(Inventor Product Design Premium 2012, Win7 Pro 64 bit)
1. When opening a Fusion DWG file in Inventor, there must be a file open in Inventor in the background for the Application Icon flyout  "Open Fusion DWG" option to appear - see attached showing same flyout with and without open background file. (Fusion Option.jpg, No Fusion Option.jpg respectively)
2. Whether there is a background file open or not, I cannot get Change Manager to launch using the standard Open... Autodesk Fusion File (DWG) dialogue option. I get message similar to "Can''t find solid body" or it opens with Fusion created edits but no Change Manager. (see Fusion Open.jpg). Change Manager will only launch when I use the Application Icon flyout "Open Fusion DWG" option.
The Inventor Fusion Change Manager and Fusion Freeform Edit Launcher add ins are loaded and set to Automatic in the Add In Manager.
Has anyone else noticed these behaviors?
Board Manager
schneik
Message 2 of 2 (977 Views)
Re: Fusion - Open Fusion DWG - Change Manager
01-15-2012 05:17 PM in reply to: mies07
Can you post a Fusion DWG file that you are trying to open in Inventor. Also is this DWG file created by opening an Inventor File or from scratch?
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
