• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    Fusion 2013 error
    273 Views, 2 Replies
    02-19-2013 06:08 AM
    Hi.
    I've been working and got the following error trying to save: "Object reference not set to an instance of an object"
    I've pinpointed the cause of the error. I can save until a fillet 2 lines.
    This is Inventor Fusion 2013 on Windows 7 x64 Pro.
    Any clues?
    Please use plain text.
    Employee
    Phil.E
    Re: Fusion 2013 error
    02-25-2013 11:29 AM in reply to: v.orlando
    Does this happen with any fillet between two sketch lines?
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    New Member
    02-25-2013 11:44 AM in reply to: Phil.E
    In the end I found out that it was that the radius was to large, once I learned how to use the tool, everything went A-OK
