Inventor Fusion
New Member
v.orlando
Message 1 of 3 (598 Views)
Fusion 2013 error
598 Views, 2 Replies
02-19-2013 06:08 AM
Hi.
I've been working and got the following error trying to save: "Object reference not set to an instance of an object"
I've pinpointed the cause of the error. I can save until a fillet 2 lines.
This is Inventor Fusion 2013 on Windows 7 x64 Pro.
Any clues?
Board Manager
Phil.E
Message 2 of 3 (553 Views)
Re: Fusion 2013 error
02-25-2013 11:29 AM in reply to: v.orlando
Does this happen with any fillet between two sketch lines?
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
New Member
v.orlando
Message 3 of 3 (548 Views)
02-25-2013 11:44 AM in reply to: Phil.E
In the end I found out that it was that the radius was to large, once I learned how to use the tool, everything went A-OK
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
