Inventor Fusion
Active Contributor tim
Active Contributor
tim
Message 1 of 7 (455 Views)
Find Features using Fusion
455 Views, 6 Replies
10-17-2012 08:07 PM
Greetings,
I am having trouble using the Find Features tool in fusion on an Inventor assembly.  The model uses lots of frame generated parts like i-beams etc.  I want to remove the corner radii on the i-beams for use in autodesk simulation mechanical.
Can anyone suggest how i do this?  I have used the tutorial and had no trouble with the sample files.
I have tried saving the inventor file as step, igs or as the native .iam.  None of this works!
Employee
SallyYang
Message 2 of 7 (451 Views)
Re: Find Features using Fusion
10-17-2012 08:44 PM in reply to: tim
Hi Tim,
Could you share us the file that can help to reproduce this issue?  Thank you!
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Active Contributor
tim
Message 3 of 7 (444 Views)
10-17-2012 09:47 PM in reply to: SallyYang
Sally,
the file is 2-6 Mb which is too big to send.  Can you send me a ftp link so I can send it?
Employee
SallyYang
Message 4 of 7 (442 Views)
10-17-2012 09:50 PM in reply to: tim
Could you send it through email: sally.yang@autodesk.com ?
Sally
Sally Yang
Employee
SallyYang
Message 5 of 7 (438 Views)
10-17-2012 10:27 PM in reply to: tim
The steps to find features like fillet, then remove corner radii.
1. Set selection filter to bodies
2. Select a body in canvas
3. Call Find feature
4. Goto browser and delete fillets (as we haven't support "Find in Browser" in TP1, you need scroll the browser to find the node with underscore shadow)
Please see attached video for detail. as it's too big, I just send it through email.
Sally
Sally Yang
Active Contributor
tim
Message 6 of 7 (434 Views)
10-17-2012 10:56 PM in reply to: tim
Sally, thanks.  Does this mean we have to do one body at a time?
Is there an easier way to do this within asm?  As I said earlier, I'm trying to mesh this model without fillets etc
Employee
SallyYang
Message 7 of 7 (421 Views)
10-18-2012 12:09 AM in reply to: tim
Hi Tim,
You can multi-select bodies by window select and find all the fillet features in these bodies. However you cannot delete these fillets at one time, as you have to select the fillets manually. And so far as I know, you probably cannot mesh this model without fillets directly in Fusion.
Sally
Sally Yang
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
