Inventor Fusion
New Member
westers151
Message 1 of 6 (432 Views)
Exact placement of holes
432 Views, 5 Replies
04-17-2013 09:50 AM
How can I exactly place holes, such as countersinks, on the face of an extruded object within Inventor?
I've watched the tutorials, however there is nothing to explain how to do this - for example, and using an X, Y axis with a known reference point, I want a hole that is 5mm along the x axis, and 104mm from the y axis.
Employee
haughec
Message 2 of 6 (421 Views)
Re: Exact placement of holes
04-17-2013 02:23 PM in reply to: westers151
Activate the hole position manipulator (click on the round, white manipulator located at the center of the hole), and then select edges from which to dimension the hole.  Dimensions should appear and allow you to edit the values.
We're working on making this more discoverable.
Hope this helps.
Charles Haughey
Fusion 360 User Experience Designer
New Member
westers151
Message 3 of 6 (408 Views)
04-18-2013 12:28 PM in reply to: haughec
Thanks Charles, and funnily enough I was scouring Google after I posted my question and came across a Youtube demo that briefly showed what you were talking about. Your explanation filled in the few remaining gaps that the video left.
Member
Stevekir
Message 4 of 6 (397 Views)
04-19-2013 07:50 AM in reply to: westers151
Getting_Started.pdf helps here, using the Ring Mamipulator, on its p 7 (or p 13 when in Acrobat /reader).
Member
gary
Message 5 of 6 (341 Views)
05-22-2013 03:42 PM in reply to: haughec
this doesnt work on the mac version Arrrrghh!!
Member
gary
Message 6 of 6 (337 Views)
05-24-2013 12:09 AM in reply to: gary
just found it...... need to do it in Sketch mode, dimension it first, then you can simply amend dimensions.....
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
