• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Active Member
    Editing Dimensions in Sketch Mode
    545 Views, 8 Replies
    11-03-2012 11:37 PM
    I've been trying to follow the basic sketching tutorial. But it seems to allow editing of dimensions, and my version of Fusion doesn't seem to allow that.
    Considering another message suggested that you could do it, I'm sure this is my error.
    So what am I doing wrong?
    I can dimension things (although the first dimension attempt in that video between the two circle centers fails) but I can't modify dimensions.
    Please use plain text.
    Re: Editing Dimensions in Sketch Mode
    11-04-2012 01:11 PM in reply to: sanguish
    When you escape the dimension command - what happens when you click on a dimension?
    Inventor Professional 2014 Edu 64-bit
    Active Member
    11-04-2012 10:15 PM in reply to: sanguish
    After having tried this for literally weeks, and having it fail, it worked. So I think I wasn't doing something right.
    Does parametric dimensioning also work then?
    Please ship this thing! :-)
    Member
    11-07-2012 06:50 AM in reply to: sanguish
    I have tried and tried to edit dimensions and NO success.  I have tried to buy a book NO success.   Looking for solutions.
    Clifford
    11-08-2012 01:44 AM in reply to: CDT12860
    CDT12860 wrote:
    ... I have tried to buy a book NO success.   Looking for solutions.
    Clifford
    Search for FREE classes here from past AU sessions by Kevin Schneider.  http://au.autodesk.com
    Member
    11-15-2012 04:31 PM in reply to: sanguish
    I have search for several hours without sucess.
    Clifford
    Active Member
    11-15-2012 09:23 PM in reply to: CDT12860
    First, definitely do the tutorials that come up (the video ones) they're well worth it.
    There is also a manual in PDF form. But i can't remember where I found it. It might be as simple as the help menu
    but, if you are working on a sketch. the sketch is in edit mode, and you're in dimension mode, you can just double click on a dimension to change it. It's the being in the right modes that is likely getting you (and was me).
    Plus, you also can do math in the field (+ - * / ) which is really useful
    11-16-2012 02:05 PM in reply to: CDT12860
    Clifford
    http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
    Member
    11-17-2012 06:20 AM in reply to: JDMather
    Thank you, thank you, THANKS.
    C
