Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Editing Dimensions in Sketch Mode
9 REPLIES 9
Message 1 of 10
sanguish
14423 Views, 9 Replies
I've been trying to follow the basic sketching tutorial. But it seems to allow editing of dimensions, and my version of Fusion doesn't seem to allow that.
Considering another message suggested that you could do it, I'm sure this is my error.
So what am I doing wrong?
I can dimension things (although the first dimension attempt in that video between the two circle centers fails) but I can't modify dimensions.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: sanguish
When you escape the dimension command - what happens when you click on a dimension?
Message 3 of 10
sanguish
After having tried this for literally weeks, and having it fail, it worked. So I think I wasn't doing something right.
Does parametric dimensioning also work then?
Please ship this thing! 🙂
Message 4 of 10
CDT12860
I have tried and tried to edit dimensions and NO success.  I have tried to buy a book NO success.   Looking for solutions.
Clifford
Message 5 of 10
JDMather
in reply to: CDT12860
@CDT12860 wrote:
... I have tried to buy a book NO success.   Looking for solutions.
Clifford
Search for FREE classes here from past AU sessions by Kevin Schneider.  http://au.autodesk.com
Message 6 of 10
CDT12860
I have search for several hours without sucess.
Clifford
Message 7 of 10
sanguish
First, definitely do the tutorials that come up (the video ones) they're well worth it.
There is also a manual in PDF form. But i can't remember where I found it. It might be as simple as the help menu
but, if you are working on a sketch. the sketch is in edit mode, and you're in dimension mode, you can just double click on a dimension to change it. It's the being in the right modes that is likely getting you (and was me).
Plus, you also can do math in the field (+ - * / ) which is really useful
Message 8 of 10
JDMather
Clifford
http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
Message 9 of 10
CDT12860
in reply to: JDMather
Thank you, thank you, THANKS.
C
Message 10 of 10
My number lock was turned off. That was my problem. I had to turn it back on
