Inventor Fusion
Distinguished Contributor
OwenWhitehouse
Message 1 of 1 (676 Views)
DLL Failed to load.
676 Views, 0 Replies
06-20-2012 09:14 AM
I just ran the installer for AutoCAD 2013 (includes Fusion 2013). I normally review the log files after installation to see how it all went, and Fusion has some issues listed.
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayAnnotationPlane.AreReferencesValid
ExecNetFx:  1>Autodesk.Catalyst.UI.Hosts, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method AssociativePlaneUtil.GetPlaneGeometry
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetLinearReference
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetCircularReference
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetFacesOnLinearRef
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetCylinderAndConesOnCircluarRef
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.FindGroundedAndSharedFaces
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method MemoryDumpUtil.DumpMemoryStatistics
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method MemoryDumpUtil.AppendStatisticsToFile
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayTrackInstEnt.GetConstrainableGeometry
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayRectangularPatternFeature.IsSmartEditableFeature
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayCylRadiusRelationship.get_Faces
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayExtrudeFeature.CanChangeToHole
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DATwoConcentricCircleLinearDim.GetReferencesForRelationship
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayCylCylDistanceRelationship.get_Faces
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewaySelectionSet.IsPlanarSurfaceFace
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewaySelectionSet.GenerateRandomPickItemOnEntity
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method SketchSpline.CreateFitCurve
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayPathPatternFeature.IsSmartEditableFeature
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayLinearEdgeLengthRelationship.get_Faces
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method SketchGridObject.get_BoundedPlane
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayRevolveFeature.CanChangeToHole
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayFilletFeature.IsSmartEditableFeature
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetReferencesForRelationship
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetCircularReference
ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetCylinderOnCircularRef
 Is this something I should be concerned with? This is my first run at deploying 2013, so I'd like to make sure I'm getting clean installs.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
