• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Distinguished Contributor
    DLL Failed to load.
    352 Views, 0 Replies
    06-20-2012 09:14 AM
    I just ran the installer for AutoCAD 2013 (includes Fusion 2013). I normally review the log files after installation to see how it all went, and Fusion has some issues listed.
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayAnnotationPlane.AreReferencesValid
    ExecNetFx:  1>Autodesk.Catalyst.UI.Hosts, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method AssociativePlaneUtil.GetPlaneGeometry
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetLinearReference
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetCircularReference
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetFacesOnLinearRef
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.GetCylinderAndConesOnCircluarRef
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DALineCircleLinearDim.FindGroundedAndSharedFaces
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method MemoryDumpUtil.DumpMemoryStatistics
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method MemoryDumpUtil.AppendStatisticsToFile
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayTrackInstEnt.GetConstrainableGeometry
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayRectangularPatternFeature.IsSmartEditableFeature
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayCylRadiusRelationship.get_Faces
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayExtrudeFeature.CanChangeToHole
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DATwoConcentricCircleLinearDim.GetReferencesForRelationship
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayCylCylDistanceRelationship.get_Faces
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewaySelectionSet.IsPlanarSurfaceFace
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewaySelectionSet.GenerateRandomPickItemOnEntity
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method SketchSpline.CreateFitCurve
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayPathPatternFeature.IsSmartEditableFeature
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayLinearEdgeLengthRelationship.get_Faces
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method SketchGridObject.get_BoundedPlane
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayRevolveFeature.CanChangeToHole
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method FreewayFilletFeature.IsSmartEditableFeature
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetReferencesForRelationship
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetCircularReference
    ExecNetFx:  2>Could not load file or assembly 'Autodesk.Catalyst.Freeway.Components.FIBodyUtil.dll' or one of its dependencies. A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A) while compiling method Freeway3DAOneCircleDiameterDim.GetCylinderOnCircularRef
     Is this something I should be concerned with? This is my first run at deploying 2013, so I'd like to make sure I'm getting clean installs.
    Please use plain text.
