• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Create a 2d cross-section from 3d proe model for 2d analysis in CFD
    290 Views, 5 Replies
    02-13-2013 08:31 AM
    I have a 3d proe assembly and would like to cut a cross-section from 3d model to do 2d analysis in CFD. I am new to Inventor fusion and trying since couple of days but not successful. I am not sure if this can be done or not in fusion but might have some round about ways to do this using both fusion and simulation CFD. Any ideas which could be of help will be appreciated.
    Please use plain text.
    Employee
    Phil.E
    Re: Create a 2d cross-section from 3d proe model for 2d analysis in CFD
    02-20-2013 09:24 AM in reply to: karuna.lade
    What is the file type you wish to use for CFD?
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
    Member
    02-20-2013 10:09 AM in reply to: karuna.lade
    I have a 3d proe model(.asm file) and opened in fusion.  I would like to cut a crosssection of the model  and have  a 2d version.
    Employee
    Phil.E
    02-20-2013 10:21 AM in reply to: karuna.lade
    Sorry about the confusion.
    I am asking what file type do you wish Fusion to create from your 3D .asm file? (so it can be opened in CFD)
    Phil Eichmiller
    Member
    02-20-2013 11:27 AM in reply to: karuna.lade
     .dwg file.
    Employee
    Phil.E
    02-20-2013 12:13 PM in reply to: karuna.lade
    Have you tried the following:
    1. Create a work plane where your slice should be created
    2. Project cut edges to gather your slice curves
    3. Save as DWG to open in CFD
    I don't know CFD but it should be able to ignore solids and look at just the 2D profile in the sketch.
    If not, you might have to delete the solid body in Fusion and leave the sketch visible. The dwg contains the sketch curves only at this point.
    Phil Eichmiller
